cleaning my egr valve
so i really need to clean my egr valve. the code for it is coming up at certain rpm ranges. i was wondering, do i have to remove the spacer or can i just remove the valve and clean that? what exactly do i spray the carb cleaner on?
RE: cleaning my egr valve
just the valve, spray in the two holes and work the plunger valve. let sit for 10-15 minutes then empty and wipe clean. then get some sea foam for the whole engines carbon build up.
