tubular front control arms
Old 01-05-2008, 03:50 AM
solid693
solid693's Avatar
Default tubular front control arms
so i have an 1989 notch and ive been doing some research on front suspension....
i want the benefits of a lighter control arm but dont want to put coil-overs in my car.... but still want to put a k-member in later!
ive been searching everywhere and it seems like nobody makes a tubular a-arm that accepts conventional springs! guys have any suggestions or maybe even advice?
solid693 is offline
Old 01-05-2008, 06:08 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: tubular front control arms
d&d does
http://www.dndmotorsports.com/?page=...ca9123a27&
as for the control arms call dave at d&d motorsports and although not listed they have the control arms for such a application you desire
mjr46 is offline
Old 01-05-2008, 09:14 AM
dillon1340
dillon1340's Avatar
so it's possible to use a tubular k member without having to use coil overs? what about a tubular k member with factory arms, is that possible?
dillon1340 is offline
Old 01-05-2008, 09:22 AM
mjr46
mjr46's Avatar
ORIGINAL: dillon1340
yep!!! call d&d and ask dave..I think it look shyty to do such but to each his own...I don't know why so many are afraid of the coil over set up..it works great and did on mine!!! and saves more weight and rides well
mjr46 is offline
Old 01-05-2008, 12:56 PM
greenstreak9205
greenstreak9205's Avatar
i think AJE sells em to
greenstreak9205 is offline
Old 01-05-2008, 01:51 PM
dillon1340
dillon1340's Avatar
i don't think coil overs would clear my tires on the front. there is like a quarter inch between strut and tire now. i'm buying my suspension right now piece by piece. have bump steer, poly front arm bushings, and caster camber plates so far. already did rear arms. i think i might check into the tubular k member conversion now i understand i may not need to use coilovers.
Old 01-05-2008, 01:57 PM
jkrum10238
jkrum10238's Avatar
this is the weirdest thing i was just about to post the EXACT same problem haha
jkrum10238 is offline
Old 01-05-2008, 02:11 PM
w8less
w8less's Avatar
ORIGINAL: greenstreak9205
[sm=exactly.gif]
w8less is offline
Old 01-05-2008, 03:33 PM
TAPOUT
TAPOUT's Avatar
Yes. I am running the QA-1 tubular K member with the stock upper and lowers. I had to grind the lowers just a hair to clear. I think it was so the control arm would swing down far enough to put the spring back in. There is a little spur that catches, and you have to grind it down.
TAPOUT is offline
Old 01-05-2008, 07:24 PM
solid693
solid693's Avatar
well.... why would i want to put coil overs in my car? im going to autocross next year and its also my main transportation... im not sure what i want anymore.... but i do know what i wanna do
solid693 is offline
Quick Reply: tubular front control arms
