cant get rear main seal out help please!!!!!!
RE: cant get rear main seal out help please!!!!!!
my77stang---the seals are not teflon they are rubber
Then you need to tell Fel Pro just that!
my77stang--- oil or grease on the inside of the seal, because running any seal dry is no good.
Once again; you need contact Fel Pro and tell them that there installation instructions are completely wrong, and they need to follow your instructions, since you've done more R&D than Fel Pro has.
Oh yeah for your information: rubber seals have a spring inside, TEFLON seals don't, just in case you ever want to tell someone that they (Fel Pro ) does make a TEFLON rear main seal.
09-16-2015 07:53 PM
1989, 50, ford, install, installing, main, mustang, out, polyacrylic, rear, screwdriver, seal, small, teflon, viton
