need help with flywheel dowel pins real quick!
ok first time doind manual clutch job. i got my flywheel and mu dowel pins. where do i put the dowel pins they seem to slide right through the holes on the flywheel.
RE: need help with flywheel dowel pins real quick!
ORIGINAL: mjr46
you should have to tap them in...are you sure you are using the correct holes???
ORIGINAL: blk89lx
They will be a tight fit. I put the dowels in the freezer overnight and put the flywheel in the oven for about 20 minutes @ 400 degrees.
Then tapped them right in.
Good luck!
Well, I just put a new clutch and fly wheel on my mustang and I couldnt get the dowl pins to go in for anything. So me and my friend didnt put them in. Should I take it all back out and put them in?
ORIGINAL: 95stang5.0
and they should be a tight fit, use a hammer and bash them in. theres no need to heat the flywheel, sometimes you need to hit stuf with a hammer to get it to fit.
