having pressure plate problems?? NEED HELP ASAP!!
when i line up clutch disc then put on pressure plate. The pressure plate will not sit flush on the flywheel...there is a small gap inbetween flywheel and pressure plate. do not want the tighten pressure plate bolt due to snapping one already. need help asap please
RE: having pressure plate problems?? NEED HELP ASAP!!
well you won't be able to sit it flush with out drawing it down by the bolts because as you tighten it down that preloads the pressure plate to the clutch disk and when tightening it down you can litteraly see the clutch fingers move on the pressure plate
if you have someone press the clutch pedal, you can make it go home and zip 2 bolts in then they can be done and your back on your own.
i like doing it that way better
