HELP ME
Old 03-20-2005, 08:27 PM
Tims 88GT
Tims 88GT's Avatar
Default HELP ME
hey everyone, i can not get my car running right, it idles a lil rough, but it is really rough like it has a fouled plug at about 900-1200, i set the tps, i cleand the maf,iac, i replaced the plugs,wires,cap,rotor. so i ran the scanner on it and i got a code 51 and a 63, so i unpluged the colant sensor and pulged it back in and then reset the tps, and i ran it again and i got a code 23, so i set the tps again, then i got a 22 and a 94, so how do you fix the 94? and where is the sensors for that, and on a 92gt automatic is their supposed to be a tube that runs from the map sensor to the intake manifold? cose their is none on mine. sorry for the long post.[:@]
Tims 88GT is offline
Old 03-20-2005, 08:48 PM
black89gt
black89gt's Avatar
Default RE: HELP ME
might wanna check injectors.. or take your MAF out and clean it or replace it.. my 89stang had the same problem.. and it was the injectors.
black89gt is offline
Old 03-20-2005, 08:52 PM
Tims 88GT
Tims 88GT's Avatar
Default RE: HELP ME
ok, i cleand the maf, and i can try the injectors
Old 03-21-2005, 08:07 PM
roundman
roundman's Avatar
Default RE: HELP ME
yes the MAP sensor should have a connection on it going to the intake manifold so it can sense the vacuum in the manifold.
roundman is offline
Old 03-21-2005, 08:22 PM
fats429
fats429's Avatar
Default RE: HELP ME
you need the map sensor hooked up very imporant sensor on S/D system it had to fall off the car will run like s**t W/O it and you got a big vacume leek the map sensor tells the coumpter how mutch manafolid vac the engin has
fats429 is offline
