Engine whine
Old 01-06-2008, 10:55 AM
Insnedrmr
Default Engine whine
I have alot of engine whine when i rev it up. I was wondering what could be causing the noise, I do know that my power steering makes alot of noise when I turn the wheel, could this be causing any problem? Thanks
Insnedrmr is offline
Old 01-06-2008, 11:00 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: Engine whine
check the PS fluid level if it's low it'll whine
mjr46 is offline
Old 01-06-2008, 11:02 AM
Insnedrmr
Thanks for the speedy reply, I did check the fluid, and its full. Its almost the the top of the tube where the cap is. Anything else? Could it be the pump?
Old 01-06-2008, 11:52 AM
mjr46
mjr46's Avatar
how is the fluid condition?? is it all murky black and or metallic particals in the fluid????
mjr46 is offline
Old 01-06-2008, 03:11 PM
DrmZero
if the ps fluid got too low at one point you could have burned it an caused a perminate whine... if thats the case, u need a new pump..
DrmZero is offline
Old 01-06-2008, 05:48 PM
stang8689
I would get a new one, they are fairly cheap
stang8689 is offline
Old 01-06-2008, 06:26 PM
ctgreddy
the whine when you rev it up sounds like a vacuum leak or something.
but i got the same ps noise when i turn too and my fluid is brown.
will be getting new pump with new fluids when i pull my motor in a month or two.
ctgreddy is offline
Old 01-06-2008, 06:28 PM
WhiteWindsor
That would be one hell of a vacuum leak if you could hear it good with the engine revved.
WhiteWindsor is offline
Old 01-06-2008, 06:31 PM
monkeyboy
Is your car an automatic? The transmission pump would make a noise if it was on it's way out. And if it's a stick... I'd say more than likely the power steering pump. But I've had a truck that whined and after I changed the clutch it went away. Either way the power steering pump is cheaper and easier to fix.
monkeyboy is offline
Old 01-06-2008, 07:04 PM
Insnedrmr
Yea its a stick..i dont think it would be a vacuum leak, cause its loud...its not a whoosh sound....its more like a vuuhhh.
(these are complicated terms)
Quick Reply: Engine whine
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
