42lb injectors or 19s?
Old 01-06-2008, 02:51 PM
LCBlackDep183
Default 42lb injectors or 19s?
K the countdown is on, in 4 days ill be doing my SC. Just nailing down some of the final details of the install. Now im running a 12lb pulley with the fmu. I have a set of 42lb injectors with a matching c&l MAF should I go ahead and step up to the larger injectors and adjust the FMU to compensate or should i stick with the 19s?
LCBlackDep183 is offline
Old 01-06-2008, 02:53 PM
telsonman
Default RE: 42lb injectors or 19s?
if it were me, i would leave in the 19s until you do your swap
telsonman is offline
Old 01-06-2008, 03:07 PM
OnyxCobra
OnyxCobra's Avatar
I would definitely step up to the 42lbers, 19's is too small for forced induction.
OnyxCobra is offline
Old 01-06-2008, 03:20 PM
kennebell92conv
kennebell92conv's Avatar
put the 42 in and get thestang tune
kennebell92conv is offline
Old 01-06-2008, 04:12 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
do the injector swap and the s/c all at once and then have it tuned accordingly
mjr46 is offline
Old 01-06-2008, 05:51 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Get rid of the c&land get a p-mas blow thru mass air. Trust me, been there done that!! JD's performance for about 255.00
PRO50SC is offline
Old 01-06-2008, 06:08 PM
LCBlackDep183
I plan on getting it tuned eventually but for now im going to run the fmu. And i will get a blowthrough as well, the only reason im looking to do this for now is to take care of it all at once. Im also worried about pushing a ton of fuel pressure through my rails as i've had a problem with one of the injectors leaking. so with the 42s im just wondering if FOR NOW i can run them safley with the fmu(its adjustable to be ran with bigger injectors) and the c&l maf.
Old 01-06-2008, 07:01 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
ORIGINAL: LCBlackDep183
Yes, you can. I ran mine like that for a while, it's just not the best combo.
PRO50SC is offline
GimpyHSHS
03-12-2018 04:16 PM
Dathan
10-05-2015 05:52 AM
4cylinderplus2
09-30-2015 05:26 PM
MacSerio
09-27-2015 01:05 PM
mltdwn12
09-23-2015 08:54 AM
Quick Reply: 42lb injectors or 19s?
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
