how to pull codes?
how to pull codes?
I believe the connector us under your hood at the firewall in the chassis wiring. Get a cheap $20.00 Ford scanner from Advance Auto or Autozone, that will do the trick. You could also use a volt / ohmmeter(analog) if you got one.
how to pull codes?
i found this while on my search for trying to figure out what my codes were, it may help...if you can figure this out maybe you can simplfy it for me</P>
</P>
https://mustangforums.com/forum_post...W=check+engine</P>
