Fuel Pressure - MustangForums.com
Fuel Pressure
Old 01-07-2008, 07:36 PM
telsonman
Default Fuel Pressure
ok, so i put on my adjustable FPR today, and set my pressure at about 30psi vacuum off, and this seemed to make it run better than when it was set at about 40. My car smelled as if it was running way rich at 40psi, so I had to drop it.
What should my pressure be at for my mods??? I'm thinking it may be pretty lean now at WOT.
telsonman is offline
Old 01-07-2008, 09:00 PM
holyshift
holyshift's Avatar
Default RE: Fuel Pressure
Iam pretty sure I run mine close to 40psi, and it runs great, you may want to check your o2 sensors if it seems its running rich, but then again, just check the plugs, and keep trying different pressures. Trial and error my friend.
holyshift is offline
Old 01-07-2008, 10:45 PM
bouchermb
I think I'm still running mine at 40 psi, even with the mods listed below, but I'd have to double check.
bouchermb is offline
Old 01-08-2008, 08:34 AM
telsonman
are yall running 40 with the vacuum off???
GimpyHSHS
03-12-2018 05:16 PM
Sixx
10-05-2015 08:36 PM
svfetter
10-05-2015 12:39 PM
88 orangepeel notch
10-05-2015 10:03 AM
mrappe
09-26-2015 11:16 AM
Quick Reply: Fuel Pressure
Featured Sponsors
© 2018 MH Sub I, LLC dba Internet Brands
