oil pump problem
oil pump problem
so i finally got the car back together and i ended up having no oil pressure. i switched gauges to make sure but i didnt want to run the car to long. i took the distributer off and i relized the hexagon rod is dropped into the bottom of the engine. my question is can this happen by taking off the distributer or does the oil pump have to come loose?
RE: oil pump problem
this happens when you forget to install the little ring that slides on the shaft to keep the shaft from coming out when you pull the dizzy up..if this pieces position is not checked after installing oil pump then what happened to you can happen.....it has to be positioned just right or the shaft will fall out when pulling dizzy out if shaft sticks in the bottom of the dizzy like it often does for a sec
If the retainer clip is not set properly or not present then it can happen. The purpose of the clip is to prevent the driveshaft from coming out of the pump when the dizzy is pulled. Time to go fishing.
thanks a lot guys. i guess ill pay a little more attention next time. the thing is ive taken the dizzy off plenty of times and havent had this problem...ill check it tomarrow...thanks again
if your lucky.. you may be able to get a large magnet and try and drag the shaft across the pan to the front drain plug opening... but it's a good chance you'll have to drop the pan down a little and fish it out with a magnet!!! this is where that one piece reusable rubber pan gasket that if you ever had to replace a pan gasket is the one you used..hopefully[:@]??? will come in handy
haha i hope i did use that gasket. i dont remember. i have a tiny magnet so ill try to fish it out...but im pretty sure the pan is coming down lol. the thing is i can see the rod through the dizzy hole so it sucks to have to do all that work when its so close lol
ORIGINAL: five0fm
alright well i tried to get it out through the dizzy hole but it dropped off the magnet and fell somewhere. i drained the oil and unbolted the pan but when i shake the pan it doesnt seem like nything is in there, there is no sound at all, is there anywhere else the rod could have gone?
