do sealants really work??
Old 01-09-2008, 09:05 PM
golden_eye
golden_eye's Avatar
Default RE: do sealants really work??
I'm sure there's not much wrong with using a sealant, but I personally won't use them. I used some in my radiator on my truck to stop a tiny leak and over time it ended up gunking up my radiator so much that I would overheat if I went over 60mph. I ended up having to get a whole new one because there was no way I could flush the old one. My brother also used some when he blew a head gasket on his old Caprice but that only lasted a couple weeks before it was leaking again.
I'm sure others have had better experiences than me though.
golden_eye is offline
Old 01-10-2008, 03:41 PM
dman302
dman302's Avatar
best case...it works...worst case...gunks up water passage in the block and creates disaster. It will destroy your rad/heater core in very little time.
dman302 is offline
Old 01-10-2008, 04:14 PM
ZachW04Stang
ZachW04Stang's Avatar
ORIGINAL: TripleJay22
i believe i may be having a head gasket leak and was looking around and seen those engine sealants that supposidly seal head gasket leaks and other leaks permanently... does anybody know if they are worth trying or if they work at all? thanks for the help
It may work but I wouldn't risk it. More then likely you will just gunk all your coolant passages in your block, heater core, radiator, and water pump. So now you'll have to pull your motor disassembly it to get the block hot tanked. Replace the radiator, wp, heater core (pull the dash), and have your block honed and replace the rings (at minimum).
Or you could spend 2 days, pull the heads, take them to the machine shop to be milled smooth and cleaned ($75-$100) and buy a gasket kit ($50-$100). Personally I would do it this way.
ZachW04Stang is offline
Old 01-10-2008, 05:01 PM
HACKGT350
HACKGT350's Avatar
its funny that you brought this up and my responce was just becareful with it i think i have a blown head gasket now. everytime i let off the gas and coast it sounds like the right side head is chirping pretty nicely. i remember my brothers 65 having a blown head gasket and making the same noise. i also had to drive from jersey to boston yesterday like that and my temp gauge would go from 170 to 200 and then drop back down pretty fast did it like 5 times it was pretty scary
HACKGT350 is offline
Old 01-10-2008, 08:46 PM
URLACHER54
URLACHER54's Avatar
i know this doesent help much because i dont know the name of the stuff, but my friend got some of this stuff at autozone and it was a blue bottle and was like $49.99 but he used it in his 93 SHO and its been over a year now and still no leak
URLACHER54 is offline
Old 01-11-2008, 12:21 AM
TripleJay22
TripleJay22's Avatar
yeah we think its the head gasket it doesnt make any noise but we cant find anything else it could be ive been losing coolant drastically and having smoke out of one side of my exhuast heavily and moisture.
TripleJay22 is offline
1TUFF302
11-05-2015 04:02 PM
Pyrate Dave
09-10-2015 07:30 PM
96stang3.8
09-10-2015 06:42 AM
JoshyGT
09-07-2015 02:04 PM
cbird1177711
09-03-2015 08:43 PM
Quick Reply: do sealants really work??
