Cobra clutch help!!! - MustangForums.com
Old 01-09-2008, 10:32 PM
phaifepoint o
Default Cobra clutch help!!!
I have 93 ford mustang with flows an short shift kit, cobra clutch.
Heres the problem my wifey bought me a corba clutch last yearfor christmas had it installed
about 6months ago an every now then my clutch pedal is hard to push an shift gears, toke it back to da shop that installed it an said they had to adjust the cable. ok that was the first time but now i already had it adjust about three times, now the shop mechanic is saying that i shouldn't have purchased a high performance clutch. need help cuzz he's telling me that i should ofused a stock clutch instead of high performance clutch.. is thistrue because pretty much everything under the hood is stock..can't afford an another clutch..
phaifepoint o is offline
Old 01-09-2008, 10:34 PM
primetime5.0
Default RE: Cobra clutch help!!!
cobra clutches are known to have a hard pedal, try a MM stock cable and see if it gets easier
primetime5.0 is offline
Old 01-09-2008, 10:41 PM
phaifepoint o
where can i find this cable?
Old 01-09-2008, 10:42 PM
primetime5.0
Old 01-09-2008, 10:46 PM
OnyxCobra
OnyxCobra's Avatar
If everything was installed properly it should work just fine. I wouldn't exactly consider the King Cobra clutch "high performance." It's a very common stock replacement.
OnyxCobra is offline
Old 01-09-2008, 10:51 PM
phaifepoint o
can you still take it out an reinstall it again, if it wasn't installed right?
Old 01-09-2008, 10:54 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
if your clutch cable feels notchy and or binds while pushing it in then the cable may have rubbed through the casing and is catching on the inside due to a frayed cable inside the casing...that's of course if it's not a new cable.......and the guy at that shop is full of bulls snot!!! I gotta king cobra clutch and it has no bearing on the pedal stiffness at all....it's not all that bad
mjr46 is offline
Old 01-09-2008, 11:24 PM
4dcobrastang
I have a Spec stage 1 in my 93 Cobra. My pedal is as hard as holding 100 pounds in the air constantly. But that clutch locks up awsome. The pedal isset at the top of my petal when I adjustthe cable which is adjustable. I have a 1/2 inch of cable pull down underneath the car to know my clutch is adjusted to the proper adjustment. If you do not have a adjustable clutch, you can buy an adjustable cableANYWHERE. 50resto.com is a good place to pick up Mustang parts. If you are handy enough, get the double or triple cable turnbuckle.
As far as the shop, scrrm them. The tranny shops specialize in ALL transmissions. Go to a specialty shop or find a local gear head that could help you!
4dcobrastang is offline
Old 01-10-2008, 05:51 PM
stanguy306
stanguy306's Avatar
My bet is its the cable....people dont always replace it when they do a clutch....its cheap insurance.....if its sometimes hard and sometimes not...its the cable...the pressure plate doesnt fluctuate....its your cable binding or....get one from ford....not adjustable just swap it out...should be all good
stanguy306 is offline
Old 01-10-2008, 09:45 PM
TTGreenSN95
My cobra clutch is way harder to push down than the stock clutch...
I bet that plastic qaudrant under the dash cant handle the extra pedal effort..you might need a new alum quadrant and one of those firewall adjusters.
I havent had any trouble with my king cobra clutch but i put the firewall adjuster and the alum quadrant on it at the same time becuase I read in here that with the performance clutches that the plastic quadrant will break...
TTGreenSN95 is offline
Quick Reply: Cobra clutch help!!!
Featured Sponsors
© 2018 MH Sub I, LLC dba Internet Brands
