i am half way there
i am half way there
I want to know what make and model computer i can use to map my engine. the setup i want is typhoon intake, bbk cold air intake, 30lbs fuel injectors, bosch or venom fuel pump. (question on size) I want a cam but i am confused. i dont need a daily driver but i dont wont a track car. so if u want to add any input on my setup etc. brands, models. i am open to all ideas. THANX
RE: i am half way there
ORIGINAL: sillyfifty
I want to know what make and model computer i can use to map my engine. (huh? for tuning? with just those mods you'll be fine) the setup i want is typhoon intake, bbk cold air intake, 30lbs fuel injectors (the stock 19's will be fine if you're not stepping up the heads), bosch or venom fuel pump (most pumps are made by walbro so dont pay extra for the middle man to put their stamp on it). (question on size) (if you're putting in any new pump, no reason no to go with 255 since its the same price) I want a cam but i am confused (worry bout the heads before just throwin a cam in there, it'll make more power). i dont need a daily driver but i dont wont a track car. so if u want to add any input on my setup etc. brands, models. i am open to all ideas. THANX
so your mods are basically a cam and intake and cai?? and you think you need 30 lbs injectors? no sir!! 19 lb's will work for that.....add some decent heads and all other supporting mods and then you could jump up to 24 lbs
