ROLLAR BLOCK
Old 01-10-2008, 03:47 PM
BLK89GT
BLK89GT's Avatar
Default ROLLAR BLOCK
Is there a easy way to tell if a block is a rollar motor. i have the upper and lower intake off and the heads. it came out of a town car i think 87'ish. the vally has the brace to hold the lifters. but no one can give me a straight answer. thanks again
BLK89GT is offline
Old 01-10-2008, 04:57 PM
Joel5.0
Joel5.0's Avatar
Default RE: ROLLAR BLOCK
ORIGINAL: BLK89GT
Yes....roller block... want to be 200% sure, check the casting number by the starter area..... E5xx, E6xx, E7xx+.... are all roller ready blocks.
Joel5.0 is offline
Old 01-10-2008, 05:11 PM
5.0stanger
5.0stanger's Avatar
Pull a lifter out and see if it is a roller...... Also, only roller blocks have the valley spider in place to hold the lifters in place, then the dogbones around the lifters to keep them from spinning in the bore.
5.0stanger is offline
Old 01-10-2008, 05:12 PM
BLK89GT
BLK89GT's Avatar
Thanx
i looked not to hard causethe wife is whining but do you hace an exact location thanx again for the help
BLK89GT is offline
Old 01-10-2008, 05:14 PM
BLK89GT
BLK89GT's Avatar
what do i exactly look for?
it has the dog bones
i just wanna be sure
BLK89GT is offline
Old 01-10-2008, 05:17 PM
5.0stanger
5.0stanger's Avatar
The end of it that rides on the cam will have a little roller wheel on it.
Old 01-10-2008, 05:20 PM
BLK89GT
BLK89GT's Avatar
i know it was a dumb ? but thanx
BLK89GT is offline
Old 01-10-2008, 05:23 PM
5.0stanger
5.0stanger's Avatar
No problem, everone needs to learn somehow. You came to a good place to learn
Old 01-10-2008, 06:16 PM
BLK89GT
BLK89GT's Avatar
so i pulled a lifter and it had a roller at the end. now i need a stroker kit and top end any ideas?
BLK89GT is offline
Old 01-10-2008, 06:46 PM
Joel5.0
Joel5.0's Avatar
ORIGINAL: BLK89GT
Stroker kit you may want to check here.
Heads and cam...... here.
Joel5.0 is offline
Quick Reply: ROLLAR BLOCK
