battery in the trunk
would it be worth the trouble or the money?? i was gonna do it to take a lil bit of wieght off the front and put it to the back... and also not many people have it done... but has anyone ever had any problems doing this?
RE: battery in the trunk
there can be problems.
1st off possible shorts and bad grounds...
2nd make sure it's nhra approved, not all are and you might not pass tech at the track
other than that, yes that weight swing helps, probably no more than an air bag in the right side coil though
but if you can use the space in the engine compartment for something else then another reason to do it
i have mixed feeleings, some have had headaches
ORIGINAL: nitrous_bob
hmmm ok question for the guys that have had absolutely no problems... mine is a convertible... fyi and how long of wires did you use??? i guessed 8 ft... havnt bought them yet though. and where did you get a good ground from??? thanks
ORIGINAL: 89 5.0 vert
