Trickflow top end kit done, just one slight problem...
#21
RE: Trickflow top end kit done, just one slight problem...
When I was a little inexperienced young'n (2 years ago) I did the TF kit too, for its simplicity. I did it right w/ supporting mods, and wound up with 302/317. No complaining here, for what I paid. You're holding yourself back with your stock injectors (and presumably stock MAF and TB).
Try replacing the plug and wire before anything else. Just swap them from another cylinder temporarily
#24
ORIGINAL: 1fastzook
it was a 306 w/9.5:1,70mmtb,190lph fp,maf 10 deg base timing
ORIGINAL: greenstreak9205
IIRC that kit is also based on a 10:1 compression motor
#25
replaced theboot from another cylinder, and still does the same...spark plug comes out wet (Gasoline) and exhaust reeks like gas
there is spark at the spark plug, although it seems a lil bit more odd that the other sparks, it seems more weak and out of time...
speaking of time...timing is set at 15 degrees +-2 (It was done with a ****ty flash bulb thingy timing gun)
Dragonus18
09-09-2015 01:21 AM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
