heater core/evaporater replacement
Well while the engine is out and I am waiting on the machine shop, I thought I would go ahead and change the heater core. I have the dash down and I also decided to replace the evaporater while I am there. One problem...what tool do you need to get the line loose?
IN2FORD
Barry
IN2FORD
Barry
RE: heater core/evaporater replacement
there are a/c realease tools or you can buy a set of cheap plastic white fuel line release tool in a holder at sears cheap..they slide over the line and you push the tool in and push the line in all at once and pull back and wham it comes off...but make sure all freon has been properly removed from the system first
here is what I use .....you can buy at sears cheap!!
http://www.sears.com/shc/s/p_10153_1...ine+disconnect
ORIGINAL: IN2FORD
once again you are fast on the keyboard!! Thanks for the info!! Anyone know of a cheap place to get the evaporator besides Autozone??
IN2FORD
Barry
IN2FORD
Barry
