spark plugs
what plugs do you think are the best to run in a 331 supercharged
RE: spark plugs
depends on the heads you are running and the plug the manufactorer reccommends..and boost level will also be important to know;)
RE: spark plugs
trick flow heads 5 to 10 boost it has autolite 3924 but im not all that fond of autolite i would like to change to somethimg different or what ever is better my heads are o ringed track heat i beleive
RE: spark plugs
ORIGINAL: bent3 trick flow heads 5 to 10 boost it has autolite 3924 but im not all that fond of autolite i would like to change to somethimg different or what ever is better my heads are o ringed track heat i beleive |
RE: spark plugs
Im running ngktr5's in a 10 psi non intercooled kb 302 which crosses over to a 3924, ngk v groove and denso u grooves were recomended by my tuner and kenne bell.
