NEED HELP!!!! Someone who knows turbo kits!!
I am looking to buy a new twin turbo kit and am wondering if this is a true complete kit except for what is listed as not included. I have a 88 t-top GT 5.0 stock as a rock, fresh motor and trans (less than 6k miles on the motor and trans rebuild). I am clueless when it comes to turbos, but curiosity has caught me. Will this kit work, any advice will be helpful. What upgrades would be recomended to use this kit, thanks for any help in advance!!!!
RE: NEED HELP!!!! Someone who knows turbo kits!!
Here is the kit components forgot to post them....
[*]X2 T04E V Band Top Mount Turbo Charger
- T4 Flange Hybrid Turbo
- .50 Compressor Wheel Trim
- AR .48
- 3" V band
- 3" Inlet, 2" Outlet
- Reliable and well built - Potential for 30+ PSI
- Wet Float Bearing
- Internal Wastegate[*]Stainless Steel Manifold
- Maximum Durability
- T3 Flange
- 8-2-1 Design Strong Tig Weld
- Direct Bolt on- NO Mods[*]Bolt On Front Mount Intercooler[*]Bolt On Intercooler Piping
- T-bolt Clamps
- Silicone Hoses[*]Internal Wastegate[*]Dual Stage Super Sequential Blow off Valve[*]Direct Bolt on Flange Pipe for Blow off Valve
X2 Oil Feed Line
X2 RedManual Boost Controller
Includes almost all necessary parts (Gaskets, Vacuum Hoses, Vacuum Tee's, Clamps, Bolts, Nuts)
DOES NOT INCLUDE: TURBO OIL RETURN LINE AND OIL PAN FITTING
ECU UPGRADE AND TUNING IS REQUIRED!!!
RECOMMENDATIONS FORHIGH BOOST SET-UPS-larger injectors,fuel pump, adjustable cam gears, catback exhaust system, spark plugs, etc.[/ul]
- AR .48
- 3" V band
- Wet Float Bearing
- T3 Flange
- T-bolt Clamps
X2 Oil Feed Line
ya, seems like its got everything, you will need injectors, fuel pump, new spark plugs (non platinum), blow through MAF, and since its a stock motor i would stay at 8-10 psi, and upgrade heads cam and intake and exhaust for full potential
http://cgi.ebay.com/ebaymotors/Ford-...QQcmdZViewItem
i think he should get it seems like a good price [sm=icon_rofl.gif]
Yepp, thats the kit, i checked and the turbos are made by garrett, seem to be decent. What components would be a good match, as far as flow through mass air, heads, intake, injetors, anything would be helpful, thanks. Any why is the kit so cheap compared to other kits, is this a very small turbo kit???
