New gauge
New gauge
Im planning to put a new temperature gauge in my car tomorrow, can i just buy an aftermarket gauge, run a wire directly to the temp sender, and that will be it? im not very good with electrical sorry.
RE: New gauge
The new gauge, if you're going aftermarket should come w/ a new sending unit. You will need to install that also. The factory one will be different as far as the gauge reading correctly.
RE: New gauge
^ Yes and also if you are going through changing the sending unit, I would advise on getting a Mechanical guage since they tend to be a little more accurate then an electronic guage based on my experiences.
RE: New gauge
ok i understand what your saying.
Nowthe gauge im looking atis cheap aftermarket gauge at advance auto parts, it is however mechanical as suggested.
http://www.partsamerica.com/ProductD...goryCode=3342D
Now it doesnt mention anything about a new sending unit....?
What gauge wire is used for the temp to sender?
RE: New gauge
ORIGINAL: 65coupe88hatch
RE: New gauge
Mechanical gauges don't use wire for the sending unit. It's going to be something like a copper line.
I prefer electrical, JMO. Haven't had the first problem w/ any of mine.
RE: New gauge
Alright thanks guys, after i finish up my last class today im gonna go and pick it up. But which is really better as far as reliabilty mechanical or electric??
RE: New gauge
ok so i bought the gauge today, now i got home and took a look into my car....where in the firewall do i drill the hole? I looked for existing holes and there arent any...
jwog666
12-27-2021 08:09 PM
andrew1969
16
01-08-2016 02:48 PM
