h/c/i problem
h/c/i problem
well i installed my h/c/i gt40's b-303 and cobra intake on a 95 GT and the car runs like crap!!! it will idle great but when i step on it it feels like it sputters and wont go any where. My timing is at 10 deg btc. One thing i noticed I pulled the plugs and there all black= to rich but why? before with the vac on it had 32 now its at 38 and 40 with the vac off. Any ideas?
RE: h/c/i problem
You should be able to get it to run somewhat decent, double check your timing. It's easy for the distributor to be off a tooth. The idle may not be great with that cam pre-tune but it should run decent.
RE: h/c/i problem
Start gathering the information on what could be causing the problem...... DIY KOEO/KOER/Cylinder Balance Self-Test ....
RE: h/c/i problem
check your firing order make sure it is correct...also make sure your balancer has not spun on the rubber at all I had that happen and when I lined up the two dots on the timing gears after cam install it looked great..but upon assembley of timing cover and balancer and pointer the pointer didn't line up on zero......I didn't think much of it and continued...well it ran like crap until I advanced the timing to adout 17 degrees according to the balancer which in all reality was about 10 degrees cause the balancer had spun almost 7-8 degrees off original....anyway just a thought
