Changing the Transmission mount
Ok so I bought an energy suspension transmission mount however I cant get the bolts loose on the old mount the ones that attatch to the trans itself not to the xmember those were easy, any tips or advice to break these suckers loose?
RE: Changing the Transmission mount
i used a very stout socket..not any thin wall stuff...big ratchet and a pipe on that to give the leverage...theyll go...just need enuf pressure..two people are good that one can hold the tranny n one can break them loose
Yeah I got them just useda breaker bar and the holow handle from an extra jack I had lying around for some extra leverage haha.
now the only problem is one of the bolts coming through the xmember broke loose and is spinning around in the mount with the nut stuck half way on the bolt. and i've tried everything to try to hold that bolt steady but I cant get any pliers on it or anything. And you cant use anything to cut the bolt either because its such a small area.
