fuel pump help (dont want to explode)
Check my sig for engine specs. I am installing a holley blue fuel pump with the regulator. I remember reading somewhere that it is set a default 14 psi fuel pressure ? I thoughtI was supposed to be somewhere around 6psi if so how do I go about adjusting the regulator.
RE: fuel pump help (dont want to explode)
On the regulator there is an allen screw with a jam nut. Loosen the jam nut and turn the allen screw to achieve your desired fuel pressure then lock the jam nut.
You need to have a fuel pressure gauge connected after the regulator. Read the instructions that come with the fuel pump. |
okay I have everything installed and ready but what should I set the PSI at?
Start with 38~39 with vacuum line off and plugged.
ORIGINAL: Novipowered5.0 Start with 38~39 with vacuum line off and plugged. |
With a carb you want your fuel pressure around 6-7 psi. On the lower side if you have an edelbrock carb. Higher than 7.5 psi on a Holley and you risk bypassing the needle and seats, flooding out of the bowl vents.
