how much HP??
how much HP??
just wondering how much horses you guys think I'm pushing with my mods.
its a very long list so bear with me.
professional products intake
professional products 70mm throttle body
accel 24# injectors
c&l 73mm mass air meter
flowtec headers & racing X pipe
flowmaster american thunder catback
kirban adjustable fuel pressure regulator
MSD blaster coil
MSD 6A
crane cams 1.7 cobra roller rockers
ford motorsport B-303 cam
stock heads
BBK cold air intake (fenderwell)
torque box reinforcement (if I can get them in)
centerforce dual friction clutch
cobra computer
cobra MAF electronics
steeda tri-ax shifter
ford racing strut tower brace
front chasis undercarriage brace
and last but not least a ZEX dry nitrous kit with a 75 shot for now.
is my fuel pump ok for a 75 shot?
I was thinking around 300 hp.
what do you guys think?
accel 24# injectors
MSD blaster coil
MSD 6A
stock heads
cobra computer
RE: how much HP??
nice.
what do you think my 1/4 mile times should be?
I seen this video of a kenne belle supercharged 2003 gt and holy crap, I need one now.
here is the link.
http://olypen.com/bulldog/movies.htm...ltestdrive.wmv
I know this isn't the movie page, but it is still my thread.
here is the link.
RE: how much HP??
next winter I am saving for some AFR 165's.
that should make a huge difference till I blow my motor.
I think my bottom end is almost done, my oil pressure drops to 19psi at idle when I race.
when I give it gas it raises to 40 psi but I don't think it is good enough, as I am using my 75 shot at the track.
RE: how much HP??
ORIGINAL: nemethjames1
300 flywheel horsepower, due to heads
and is it possible to port the exhaust side while the heads are still on the car?
RE: how much HP??
As for your HP question, basically running what I am cept for underdrive pulleys.
So I'll say around 260RWHP
Stock heads and B cam and everything. Slightly different manifold and exhaust but whatever[&:]
What type of headers also?
That'll make a nice difference in power.
Bah I'll just post my engine mods and you can compare as to how mine dyno'd
And you still running the stock fuel pump?
If so, it can barely support the stock 302 [:'(]
You will need a bigger pump.
[ul][*] Ford B303 Cam[*] Steeda Aluminum Underdrive Pulleys[*] Edelbrock Performer RPM Intake[*] 1" Phenolic Spacer[*] 24# Injectors[*] Pro-M Bullet 75mm MAF for 24# Injectors[*] Accufab 70mm TB[*] Edelbrock 70mm EGR[*] BBK Fenderwell CAI[*] BBK 29-74psi Aluminum Fuel Pressure Regulator[*] AC Delete Kit[*] Smog Removed[*] Electric Fan[*] Superchips Custom Tuning Flip Chip[*] BBK 1 3/4" Ceramic Coated Long Tube Headers[*] BBK 2.5" Off Road Shorty X Pipe[*] Magnaflow Magnapacks Catback
[/ul]
Just posted the poweradders/free'r-uppers
not including my nitrous, for the full list of mods and a slightly older dyno sheet(changed a couple things since I did that) click my sig's picture.
Atleast it will give you sort of an idea.
[/ul]
