smog pump uninstall
#34
RE: smog pump uninstall
The thing is, the tensioner has smooth surfaces, are you sure it's safe, or good for the life of the belt to run the grooves over the smooth surface?
Also, no matter what, there is still part of the belt moving under the tensioner, so it's about the same as routing it under the tensioner instead of around it...
#36
ORIGINAL: Demon_Mustang
If I remember correctly, the heads are tapped where the bosses cover up and there may be these threaded inserts screwed into the threads for accessories if that head was used on the other side at the factory, so like I said, you never know what size bolt it is until you try. Or, you can just weld the bosses up and bolt them back onto the heads.
Good luck, man.
#37
ORIGINAL: Dbeck002
what solenoids are you talking about? where exactly?
if you are standing at the front of the car on the left side right behind the strut tower there is a bunch of crap that was hooked up to the smog stuff..
do you guys know if it will trip a check engine light if you disconnect them?
jwog666
12-27-2021 08:09 PM
mrappe
09-26-2015 10:16 AM
