interior lights.
interior lights.
All my outside lights work fine but none of my interior/dash lights come on.. besides a bad fuse what else should I look for? Could the brightness adjuster be bad? if you have had this problem and fixed it please reply.
RE: interior lights.
It could be the headlight switch. The headight switch is a common problem. The usual problem in the circuit breaker overheats and shut the headlights off. The other thing to check is if the clock led dims when the headlight switch is on. If not, it is a related problem and points to the headlight switch.
ORIGINAL: mustang8719
The dashlight dimmer switch in another common problem with dashlights not working.I had the same problem and replaced the dimmer switch and fixed the problem.
treesloth
09-28-2015 07:03 AM
