rebuilding the heads?
RE: rebuilding the heads?
depends on if the valves and seat need to be cut and or if it'l need valve guides...a machine shop would have to do all that and you'd have to put a decent set of springs on to match the cam you have..if it's stock then no worry there...very least..I'd check all the valves and seats and relap them if need be and replace the seals..and paint 'em blue and call 'em new!!!
a valve job and resurface should cost between 150-250 bucks, you'll get em back looking and performing like new. if you want a bigger cam you can drop off your springs when you bring the heads in. new springs are around 100 bucks for a rough ballpark.
