Tranny grinds into reverse. Help?
My transmission is a 5 speed manual. 1989 ford mustang LX. Transmission grinds into reverse 50 percent of time even with clutch fully engaged and going slowly. Is my synchro going bad or is there some other possible explanation?
RE: Tranny grinds into reverse. Help?
I have a 91 Gt and the same issue. Try starting in 5th gear first or shut off car and then put it in reverse and start. I have been reading and found this is a know issue.
I would love to have this corrected myself.
My Toploader is unsynchronized reverse, just put in the clutch, put in in first to synchronize it, and keeping the clutch in, then shift into reverse. That's provided your 1st synchro works though.
reverse doesnt have a syncro gear so that way when ur slammin 3-4 or 5-4 and u go into reverse by accident...its grinds, thus saving you and your transmission. if it had a syncro gear and you made that mistake....goodbye tranny
ORIGINAL: StangKid5.0
my ride does the same thing just put it in 5th the reverse and no grindage
