problem with egr valve on a 95
Hey guys im having an issue with my egr when i added the few mods on my car and had the egr hooked up the car would idle ok but would run like total crap.So i bypassed the egr and it runs great but it idles at 900 instead of the 600 normally,so my question is,can it be a bad egr or do i just have it remapped and take it out of the loop or just deal with the high rpm,i dont know if you can run the idle back down to hear the chop on this yr mustang or not.So any info you guys have on this will be great thanks alot.
RE: problem with egr valve on a 95
Check the EGR base plate for a vacuum leak. What the system does is simply not add spark advance to compensate for the exhaust gases injected by the EGR...... A/F, base and load based (NPI) tables are left intact.
ORIGINAL: blairs95cobra
Maybe I missed something with the 5.0?
Thanks alot bro i will give that a shot.Will it change anything if i decrease the idle to compensate for what the lack of a egr is doing,or will it effect my proformance?
TfcCDR
09-14-2015 12:08 PM
zanemoseley
09-06-2015 12:58 PM
