Starter
RE: Starter
Do you have a soleniod on your starter, or is it a one wire starter? Take the s-terminal wire off the fender mounted relay and see if it stops. Ifyou have a soleniod on your starter make sure thepositive cable is not touching the s-terminal. Make sure nothing is shorting to the fender mounted relay. Last resort fender relay is bad or soleniod on starter is bad. Most likely cause is incorrect wiring if this happened after you replaced the cables.If power is being sent to the s-terminal wire on the fender relay with the ignition off suspect the ignition switch.
logan409
09-26-2015 07:43 PM
jaiidutch
09-14-2015 10:29 AM
