Question for SN-95 guys w/ tubular k-member
is this mod a bolt in deal or is the stock k-member rivited in place? I know that there are bolts but is that all that is holding it in? Is there a way to do this w/o pulling the motor? Thanks for the help
RE: Question for SN-95 guys w/ tubular k-member
yes it's a bolt in deal..but you'll need to remove the rack or pull it out of the way..I had to remove the steering shaft on mine....but none the less it's not that bad......I had my motor out but if you are doing it with the motor in place..you'll need to support the engine from above with a craddle or brace...you can build something
ummm...i dont have a craddle or anything...is there a possibility thati could use a jack stand and put it at the bottom of my motor under the oil pan and use a 2X4 across to distribute the weight on it?
svtmicah
06-22-2006 05:38 PM
svtmicah
03-03-2006 01:14 AM
