whats all needed for T5 swap
RE: whats all needed for T5 swap
harness for back up lights, neutral safety switch harness. starter, different plate, proper bolts. autos are different then manual ones. speedo cable but you can make yours work.
your stock starter will work and so will your cable you just need a diferent gear the t-5 one is smaller than the aod one. i would not use a stock quadrant that adjust on there own there a pain. get a fully adjustable one.
also you already have a neutral safety switch in your car all the mustangs do on autos ford just ran a loop through it. it is on the right kick panel up with all those rat nest of a wires the loop is black theres two plugs one has the loop and the other is clear they should be right next to eachother.
Matt's 95 Stang
10-05-2015 07:16 AM
cardsrus1
19
09-15-2015 08:37 AM
jaiidutch
09-14-2015 10:29 AM
