1995 331 stoker idle problems
i got a 95 gt with a 331 in edelbrock heads cam and intake 75mm throttle body 24lbs injectors cold air intake roller rockers short thow shifter flowmaster exhaust the car will not idle when u come to a stop at at light it will die it will idle down and then die unless u give it gas can any1 help
RE: 1995 331 stoker idle problems
did you perform a idle relearn?? and reset the KAM/COMPUTER...by disconnecting the battery then setting tps and following idle relearn??..also what cam have you got??? alot of sn-95's ecm are hit or miss and may require a tune for the idle issues as you may know
the only way i could get mine to idle is to open up the buterfly a little then I had to reset the tpssensor now it idles.
the motor would stop when I stopped.
If you dont have that guage to read the sensor I paid 5 bucks for mine at harbor frieght.
If you race that car in the near future I would love to know what times you run Im looking at a 347 or a 331 swap towards the end of summer. what cam did you go with?
dalefrancis88
09-11-2015 07:15 AM
