Popping Noise
Popping Noise
I here a popping noise when I go forward or in reverse if I tap on the brake a little hard, It popped going around a corner kinda of hard as well, the noise is coming from the drivers side, I have already checked the lower ball joint, the control arm bushings and some of theother suspension components and they all seem tight. Anyone know what this could be and do you have some suggestions on how I could test any of the other components on the car. Thanks
RE: Popping Noise
possibly but I doubt it..does it do it all the time?? tracking down a noise over the internet is really tough without hearing the general noise or location....= tough......but if you can get it to do it rolling slow..I'll usually hang my head out the window while trying to duplicate the noise to narrow down the source/orgin of noise
RE: Popping Noise
It seems to do it more and more frequently. Just rolling without hitting the brakes will not do it. It seems to only do it when you step on the brake quickly or taking a fairly hard turn into a corner, not just slowly stepping on the brake in a normal stop. It is coming from the drivers side for sure, I know internet diagnosis is tough, I have held my head out the window also, can't figure it out since all the suspension seems tight.
KingRando
10-02-2015 08:06 AM
