long tube headers
RE: long tube headers
BBK arent for an auto, when i was looking at long tubes the only two brands that i saw that made longtubes were mac and pacesetter, im sure theres more out there but i didnt put much effort into the search cause i changed my mind and ended going with equal shorties
If you decide to go with MAC. Get them from hardcoremustangs
You will get the best deal through him. He is also an official site sponsor. Make sure you tell him that I sent you too.
Most of you guys are use to foxes with these sn 95 cars theres only bbk mac and pacesetter for longtubes and mac is the only company that has them listed as 5spd or manual others told me manual only, having a 94 automatic sux sometimes.
I just got the summits no problems with em so far and i havent heard any problems with em, Its all about what you want, longtubes will give you more lowend torque while shorties will give you more high end horsepower, but if your planning on stroking it out ever then definitly get longtubes a stroker needs 2 breath.
ORIGINAL: cougarfan088
well i am building it up to a 331 stroker, but i might do the patriot heads, i am putting on underdrive pulleys, MAF cold air intake, upper and lower intake manifold,throttle body,and i am rebuilding the tranny with a tci valve body, tranny cooler and ratchet shifter, and probably some 4:10 gears..and then all new ignition..
grab a set of AFR's, Canfields, RHS (with a small modification to your intake), or TEA's
