EFI to Carb
RE: EFI to Carb
ORIGINAL: onesickstang01
yea the intake, heads, cam. those are the biggest ones. port match intake and heads. get exhaust, tune the carb right and you are pushing some nice HP. much easier than EFI
RE: EFI to Carb
if your just talking about a carbed v8 then really just manifold, heads, and cam. but if your talking about putting that engine into a vehicle that had efi then it depends on the car and what is controlled by the ecm. If you have a car with a trans that uses ecm info to tell it to shift then .... ?!(maybe someone else should chime in!!lol)there is alot ofinfothat the ecm uses from various parts of the car and when you take away one of those parts you effect the whole system.
RE: EFI to Carb
Carbs are great for a lot of reasons. A properly tuned carb can produce excellent power and throttle response with decent mileage, and very good drivability. I'd have to say that 90% or greater of the issues that I hear people complaining about with carbs, are tuning issues. A poorly tuned carb will run like total crap, if it runs. Carb's advantages are only realised when properly tuned, and you need to know what you're doing with them. I wouldn't count on most tuners these days, since many of them don't know jack about carbs, and if they know anything, it's usually not enough to tune one properly. Finding a good carb tuner these days is very difficult to do. Once you understand how they work, and get familiar with your carb, tuning them is rather simple, but can take time to hammer out drivability and throttle response bugs, which is a pia at times. There are good books, and dvd's out now on how to tune carbs, plus plenty of us here have a bunch of knowledge on them to help out if you choose to go that route.
I know a lot of people who like carbs just for the simple reason of it clears up clutter in the engine bay. I'm a huge fan of less crap myself.
If you try to switch an EFI car to carb where the computer controls systems OTHER than the engine, such as traction control etc, then it's a whole other ball of wax that can be a major headache.
RE: EFI to Carb
So what about a 93, isn't the speedo electronic? Would going to a carb setup mess with that?
I just think the carb setup would be A LOT easier in the end. If you want to change anything over you don't have to worry about chips/tuners and all that good stuff. That and like you guys have said you don't have all the mess of the wires under the hood, makes things look alot nicer.
I plan on messing with it a bit more to see what I can figure out. Are there any good books on EFI. Maybe an EFI and tuning EFI for dummies?
RE: EFI to Carb
ORIGINAL: hemi_04d
RE: EFI to Carb
People that dont believe in Carbs, needs to know something.
TODAY'S CARBS, are built SOLID, durable and of revised error correcting internally, that the past Carb's designs have always haunted us.
What does that meen?
It means, when you buy a Aftermarket Quality Carb, it will carry similiar characteristics of a fuel injected car.
Gas wise, you might lose 2 mpg or gain.
Bad theories : cold start and idle issues, blah blah blah, are all false, and that 86 Camaro next to me, has been running the same original carb since 1986, with nothing but clean exhaust emmisions and a smooth idle of 700 rpm exact.
RE: EFI to Carb
ORIGINAL: ram2sak
don't forget about the efi fuel pump. it'll push way too much pressure for a carb even if you put a regulator in
RE: EFI to Carb
ORIGINAL: H0SS302
you just turned me on to the carbed motors, looks like ima be rollin in a 4eyed fox
