Vibration I need some help
RE: Vibration I need some help
my car shakes real bad and i really noticed it when i put on my brakes. One day i was changing my tires and had my car up on a jack and me and my dad seen the tire was wobbling. Come to find out my axle is bent. Prob gonna fix it this weekend, I hope it fixes all the problems.
yeah but somethin like that is not my problem because it dose it in park, and while driving, it has something to do with the motor i know that. hope the axel fixes your problem, no one likes a rough ride
how many ft lbs should it take to turn a motor with the heads on and plugs out? so its not making compreshion but it is lifing the valve springs like i said before the motor is stock so it dose not have a very tough spring, it takes 55-56 ft lbs in one spot, and the rest of the way around it takes like 40-45 ft lb?
ORIGINAL: Tims 88GT
im going to pull the motor as soon as i get a chance it is raning right now, i have everything unhooked and redy to go, it will go about 3/4th around untill i get the 55-56 ft lb reading on my tq wrench, the motor in my 88gt took 7ft lb to turn the short block that is why i am worried, their is a major diff between the two. the only other thing im moving with this is the valve springs and that shouldent make that much diff should it?
Update: Vibration I need some help
the keyway on the dampner is like 3/4 inch long, and the bearings main and rod bearing were chafed/jumped so the crank was hooping/wobbling, and some of the main caps were only 50-65 ft lbs and their supposed to be 80-85, talk about somthing flying apart. lol
