Cruise Control problems....
So my CC seems to work when ever it feels like it. Sometimes it works, and sometimes it doesnt. Any suggestions on what is causing this? Any help is appreciated.
RE: Cruise Control problems....
The only help I have for ya is , do A good visual inspection of everything related to it, I looking in the Ford Manual and there is bunch of tests to do, It looks like the most easiest would be
check for vacuum to the servo, check the servo itself by replacing it with another, and perform a host of different tests on the control circuit and switches. There is alot to it . Good Luck1
Your servo is probably just going bad.
Its vacuum controlled and the inner rubber parts will deteriorate after a while.
Control unit is located in driver side qrt pnl, just in front of door hinges
I think they cost like $100 to replace.
breaking
10-02-2015 01:27 PM
