cam???????
cam???????
first post ever on any ford sight..... building a 93 5.0 with AFR 185 heads bbk ssi intake, stud mounted harland sharpe 1.6 rollers,full length headers ford 9 inch with a c4 and 3.50 gears bottom end is bone stock with 40,000 miles on it.........question stay with stock cam if not what are the recommendations thanx
RE: cam???????
well for one...ditch the bbk ssi thought= intake sucks as well as it's ugly....and as for the bottom end....you'll need to notch the pistons to clear the 2.02 valves the 185's have and as for a cam a comp 270 hr is a decent ots cam or a tfs stage 1 ots cam..or custom cam for matched combo
RE: cam???????
+1 onditchingBBk intake. Find yourselfa nice tubular GT40 intake. If I remember correctly they can handle about 400-450hp without choking the engine. Alot of people use the recommend the Trick Flow intakes but the GT 40 looks the best in my opinion. I would get a Trick Flow stage 2 if it was me but like Mjr said you can also get a custom grind for your setup.
RE: cam???????
The BBK intake will be just fine.
Get a custom camshaft from Ed Curtis @ www.flowtechinduction.com. He sells the AFRs you are talking about and can get you the CORRECT springs to go with the camshaft.
$325 for better performance and driveability
junior04
09-28-2015 10:53 AM
