brake noise i think?
RE: brake noise i think?
when does the noise /bearing sound occur loudest??......when turning hard right or left?? if it sounds like a brake issue..first thing I'd do is remove drum and inspect components and linings for any issues
mine did the same thing on my passenger side i took it apart found nothing wrong drove it again still did the same i asked around and i heard if the brakes were backed off enough they would do that so i adjusted the brakes up a little and it fixed it try it because my parking brake was fine and felt like they were tight so i think you should try that
Matt's 95 Stang
10-05-2015 07:16 AM
09-25-2015 06:42 PM
Ghost_Conscience
09-23-2015 02:17 PM
