Can't get autometer 5" tach to work?????
Alright well im putting a autometer tach in my friends car. I put a sunpro in the my car and it works great. Well anyways I have the white wire hooked up to the light switch and I go the backlight on the tach to work. I have the green wire connected to the negative side of the coil in the exact same spot I have mine. I have the red wire wired into a ignition wire that comes on with the car and I tested that and it pulls 14 volts when it only requires 12 and of coarse I got the black wire connected as a ground and even tried running it directly off the negative battery cable? Is there something im missing?
RE: Can't get autometer 5" tach to work?????
is the stock one working still..i did that once and turns out it was a bad fuze.....if not recheck the connection to the neg side of the coil. i ran mine right off the existing tach wire...tan and yellow in my 92.
Ya the stock tach is working fine but does like to stick once in a while. I checked the connection and it was 14.08 volts from the wires off the coil?How can I find out what wire powers the stock tach?
well i went online and got a wiring diagram...mines a 90-93...but it says its hte same colors as 87-89....when you take the stock cluster out there are two clips, the clip on your left is the one where the tach wire is...mine was tan with a yellow stripe. i got a florida 5.0 gauge cluster so i connected the autometer right to that wire and it works great.
I will have to try that. I have another old tach lying around I might just try that and see if its a bad tach. Correct me if im wrong but to test a tach dont all you have to do is have someone touch the redwire on the positive side of the starter cylinoid and the black to a ground then touch green tothe negative side of the coil?
Sounds like you have a bad tach or one of the wires that are attatched to the tach are broken at some point in its harness. I don't know about the testing a tach though.
