19lbs. injectors?
19lbs. injectors?
im doing a H/C/I swap, 93 Cobra intake, true GT 40 iron heads, F-303 cam, can i still use the 19lbs injectors with this set up or do i need to upgrade to the 24lbs injectors.
RE: 19lbs. injectors?
19's should work okay but with your cam choice and it being an auto and on top of that speed density.....[&:]..comp xe 270 cam would be a better choice = same lift but better lobe seperation spec for SD
1988 GT automatic, hypertech chip, mac underdrive pullies, BBK shortie headers, UPR hi flo X pipe catted, Flowmasters, TCI shift kit, cold air intake, 70mm MAF, 70mm throttle body, 3.73 gears
