New Car (Batterie Issue's) Please Help -.!!!!
Old 02-07-2008, 10:01 PM
92FOX
92FOX's Avatar
Default New Car (Batterie Issue's) Please Help -.!!!!
Ok so i bought a new 1993 Mustang GT 5.0, Nice car just having a headache right now !!!
Batterie light comes on , The guy that i bought the car from said when he put the new battery 1 week ago he had to put new battery terminals, so when he did that he got confused on the POSITIVE+ & NEGATIVE- . Wind up switch the cable's and he said he seen smoke from the fender wall?
So i replace the - Silinoid - And the Fusable Link, to the positive. becuase it blew!
Still battery light.!!!!!!!
Ok so i got my batterie out of my 91 NOTCH .
STILL BATTERIE LIGHT???? Over all
-New battery
-new terminals
-new silinoid
- new fusable link
WHAT TO DO!!!
92FOX is offline
Old 02-07-2008, 10:07 PM
92FOX
92FOX's Avatar
Default RE: New Car (Batterie Issue's) Please Help -.!!!!
bump, Please im begging for HELP!
92FOX is offline
Old 02-07-2008, 10:09 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
probably toasted the alt!! you need to have the alt professionally load tested and it's output checked
mjr46 is offline
Old 02-07-2008, 10:10 PM
92FOX
92FOX's Avatar
Should i Disconnect the ALTENATOR and take it to Advance Auto Parts ,!
92FOX is offline
Old 02-07-2008, 10:15 PM
92FOX
92FOX's Avatar
Is it posible maybe i didn't Set up the Silinoid Wiring Right?....
But waait if i didn't set it up right it wouldn't of started at all right?
Maybe i didnt do the Fusable link right lol..
Maybe i just a jinx and cant do nothing right lol.
92FOX is offline
Old 02-07-2008, 10:31 PM
mjr46
mjr46's Avatar
if you have a multimeter you can check for the proper level of charging voltage at the battery....if the alt is working.. you should see at least 13.8 volts charging and amperage should vary depending on the load induced at the time of your measurement.....I'd turn on all the lights radio and a/c so you know that a measurable amount of current in amps can be seen......but if with a load on the system if you have close to 0 or - amperage draw...battery is being discharged/alt not working..........the charge wire for the alt is usually on the side of the selonoid that goes to the battery or on the pos batt post.....mine is rewired like such cause I have a one wire hook up alt that is self exciting
mjr46 is offline
Old 02-07-2008, 10:33 PM
paulstang
paulstang's Avatar
Go get the altenator tested. Thats your best bet.
paulstang is offline
Old 02-08-2008, 01:13 AM
hatchdemon89
hatchdemon89's Avatar
alt is dead sounds like
hatchdemon89 is offline
jjwinel78
08-17-2015 03:34 PM
drumhedd2005
08-13-2015 09:59 AM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
'stangdude
08-12-2015 01:27 PM
Quick Reply: New Car (Batterie Issue's) Please Help -.!!!!
