Trick Flow Trackheat from summitracing
ok soi have a 88 mustang that has a 93 cobra motor computer and everything. I am wanting to go with the trick flow track heat kit with new roller lifters i pressure fuel pump and a fuel pressure regulater any suggestions or concerns about this setup??????
RE: Trick Flow Trackheat from summitracing
When you say "Kit" are you referring to the H/C/I kit?
If so, you should also think about bigger (24lb) injectors, Bigger MAF, TB, EGR Spacer, new plugs/wires,and I am sure there are other things that I am forgetting about....
Keep in mind, when you open up one area, you need to compensate in the other areas to keep everything balanced
ok well i didnt explain well enough i am going with the trickflow track heat complete kit from summit racing i already have 24 pound injecters mas air to match in and a bbk 70mm throttle body and i am thinking of a intake spacer anymore suggestions
ORIGINAL: BLK89GT
read the small print all the stats on that kit where done on a 306 not a 302!!!!!!!!!!!!!!!!!
Luke9222
10-22-2015 11:55 PM
09-10-2015 08:39 PM
