What To Do With A 1000$ stock engine
RE: What To Do With A 1000$ stock engine
on a stock motor u wouldnt be able to puit a whole lot of nitrous on it to get that h.p and then u also have to put in consideration of mileage on the motor and how much wear ull be putting on the motor with just a 100 shot.. if the rode hold
ya! well i think as of right now im gonna try and build up all the aprts like
-MAF
-underdrive pullies
- Throttlebody and spacer
- shiftkit
- cam and valve train
- gt40 heads and intake
that should be up around 320 or so you think?
-MAF
-underdrive pullies
- shiftkit
AMEN TO THAT! [sm=nxsmile.gif][sm=nxsmile.gif][sm=nxsmile.gif]
ORIGINAL: mjr46
yeah you say that until you throw a simple 100 shot on... it'll kick you in the ace more than anything you've ever felt!!! NOS FTW!!.....CAM SWAP = VALVETRAIN SWAP TO MATCH
ORIGINAL: jerod187
no i understand i just prefer all motor! what cam would be best for the gt40 heads and intake? also if i buy used heads will i need new lifters springs and everything? also what else should ia hev done to the head s by a machine shop??
ORIGINAL: jerod187
-MAF
-underdrive pullies
- shiftkit
-MAF
-underdrive pullies
- shiftkit
My first round of motor building isn't much different than what you are thinking:
'95 Cobra GT-40 Heads (Ported and Polished) - $200 for heads, $500 for rebuild and machine work (yes I know I could have aluminum heads... I don't want them at this time)
Cobra Intake (Upper extrude honed [bought it that way], lower ported and matched to heads) - $300, machining bundled with heads
F cam or similiar (waiting on flow numbers from heads) ~$200
Valvetrain - $500 (springs, locks, retainers, push rods, roller rockers, etc, etc... estimated budget)
I will be THRILLED if that combo puts 300 down to the wheels (and I'm betting it does).
Subtract the machine work and all injection parts, and I'm at $1200... I paid high on the intake (extrude hone) and low on the heads, so I call the two an average.
But, with my budget in mind and quality parts, I'm hopefully for a VERY reliable build. If I add N20 or a blower to the mix, I should easily be able to exceed the horsepower capacity of the stock block.
Anyhow... Good luck.
Gt40 heads/cam/intake along with all the supporting hardware is going to perform right around where the 93 cobra's did....240-260 to the wheels and a nice powercurve on the street. Nitrous is great but upgrading before using it makes it all the better. Go for the parts you've listed and enjoy.
YoungStangsMan
09-05-2015 07:01 PM
