moroso shut off help ASAP
Old 02-09-2008, 03:55 PM
benz5800
benz5800's Avatar
Default moroso shut off help ASAP
i just got my moroso shut off switch but i cant seem to make sense of the wiring diagram can somebody please simplify it for me or send me some pics of how yours is set up thanks
benz5800 is offline
Old 02-09-2008, 04:06 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Default RE: moroso shut off help ASAP
This may help
PRO50SC is offline
Old 02-09-2008, 04:16 PM
mantis118
mantis118's Avatar
Thanks pro50sc. I was wondering the same thing.
mantis118 is offline
Old 02-09-2008, 06:21 PM
benz5800
benz5800's Avatar
now what do you do if you dont have a one wire setup on your alternator
benz5800 is offline
Old 02-09-2008, 06:23 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
That has nothing to do w/ it. The wire you see is the new 12 volt feed wire to power the alt. You will disconnect the stock feed wire that runs from the solenoid to the back of the alt. Understand?
PRO50SC is offline
Old 02-09-2008, 06:33 PM
benz5800
benz5800's Avatar
no honestly you lost me. okay i have a positive from the battery going to the switch then on the other switch terminal i have a wire going to the starter solenoid i get all that but what wire has to be run from the alternator to the switch. i have a factory alternator which has a plug with 3 wires coming out of it and then under that is a single wire that attaches to a male connector on the alternator.
benz5800 is offline
Old 02-09-2008, 09:06 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Oh I see. You're still running the factory alt. OK, you'll have to cut the 2 power supply wires to the alt and connect those to the new wire coming from the cut off switch w/ a fuse as illustrated in the diagram.
PRO50SC is offline
BOB ROME
07-26-2023 01:54 PM
Nick Oliver
10-17-2018 04:22 AM
DJ Piner
09-30-2015 03:03 PM
dalehunter
09-25-2015 10:51 AM
Quick Reply: moroso shut off help ASAP
