would i have to flycut?
im getting a new cam ....had the b 303 cam....want a bigger one...but not to big so i dont have to flycut my pistons...... would i have to fly cut with this cam??....
COMP Cams Nitrous HP Camshafts
Camshaft, Hydraulic Roller Tappet, Advertised Duration 274/ 286, Lift .555/ .570, Ford, Small Block, Each
RE: would i have to flycut?
Install the new cam, head (using the old head gasket), pushrods on one cylider, and roller rockers. Before you put the head get some modeling clay and put it on top of the piston where the reliefs are. Slowly and gently spin the motor over a couple of revolutions. While you turning the engine over it locks up do not try to force it, that is the piston hitting the valve. If it goes ok take the head off and check to see how thick the clay is where the valve pushed into it. You need .120" on the intake and .080" on the exhaust to be safe.
alright thats what i thought u meant....the 2 cams arnt that different the duration on the comp cam is small but slip b,c its a nitrous cam...the lift is bogger the the b cam...which one should i be worried about?
