Distributer 180 out?
RE: Distributer 180 out?
info taken from http://www.geocities.com/cping3/late302.html
There are three kinds of 302s made from 1982-2001.
[ul][*]5.0L HO This engine was used in 1983-1995 Mustangs, Mark VII Lincolns, and some T-birds and Cougars. All Explorer 5.0L engines are 5.0L HO engines as well. They use the 351W firing order, 1-3-7-2-6-5-4-8. Except for the 1983-84 Mustangs, all of these engines are roller cam equipped. They use a reverse rotation water pump and front cover. The 1994-5 Mustang and all Explorers use a unique front cover and water pump.[*]5.0L Full Size Car This engine was used in 1982-1990 Crown Victoria and Grand Marquis. They use the 289-302 firing order, 1-5-4-2-6-3-7-8. Most of these cars are not roller cam equipped, however sometime in the early 1990s they started using roller cams but retained the 302 firing order. They use a standard (clockwise) rotation water pump and front cover.[*]5.0L Truck (except Explorer) These engines are similar to the Full Size Car engines, except they use different intake manifolds and camshaft profiles. They also use the 289-302 firing order, 1-5-4-2-6-3-7-8. They also began using roller cams sometime in the early 1990s. They use a reverse rotation water pump and front cover. [/ul]
k cool
hey adder a off topic questionn
i just gapped my plugs to roughly 55 on all of them, and i replaced some old ****ty looking ford racing red wires im guessing 9mm with Motocraft 8mm wires, and im having a random miss can i attriute that to the wires? some of the wires don't clamp down securly on the cap, like ill push it down and 2 days later ill go back and ill have to push it down again... its pissing me off lol... should i just throw back on the ford racing ones?
