need help! blown rear
Old 02-12-2008, 09:02 AM
92redgtstang
92redgtstang's Avatar
Default need help! blown rear
have a 91 5.0 aod with 30k miles on car. have a grinding noise coming from the rear pumpkin. was planning on putting in 373 gears, problem is now what else do i have to replace? checked the fluid in rear and had metal fragments in it.
thx john
92redgtstang is offline
Old 02-12-2008, 09:44 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: need help! blown rear
so pull it apart and inspect wheel beaings and all carier and pinion bearings
mjr46 is offline
Old 02-12-2008, 10:04 AM
HACKGT350
HACKGT350's Avatar
when you do new gears you wanna replace the bearings anyway so get yourself a bearing kit shims and all that good stuff new trac lock clutches spider gears and you should be set
HACKGT350 is offline
lincolnshibuya
09-24-2015 10:46 PM
stangin1996gt
09-21-2015 11:01 AM
rdog69t
SVT Forums
09-13-2015 06:16 PM
cbird1177711
09-02-2015 04:12 PM
Quick Reply: need help! blown rear
